Thread: TGV wiring deletion help
    Jul 2017
    The Villages Fl.
    I just started my wiring diet of my 04 WRX engine wiring harness. I have read volumes about the wiring delete threads for the last few years, but have not found anything specific on the TGV wiring. I deleted the TGVs and want to know the best way to delete the wiring. Should they just be eliminated or ?
    Appreciate any help you can give.
    Quote Originally Posted by redbudrr View Post
    I used the two TGV position ECU inputs for oil pressure and oil temperature.
    Senior Member mistasherm's Avatar
    East Central PA
    Are you asking if the wires and connectors should be deleted or just left as part of the harness? I have same year donor, I deleted my TGVs and the connections. But like Bob mentioned above - there are some components where I eliminated only the connector because I felt that the inputs could be used for other powered accessories. But when I did eliminate connectors AND wires I removed back to the ECU, FB, or splice point.
    Jul 2017
    The Villages Fl.
    Thank you both. This answers my question.
