I have a 302 from 99 explorer, no heads or intake. I got some 351 heads from a 1978 302 to install. So I assume I will need:
351 intake
Push rods from 302 ?
302 timing cover
302 water pump
Distributor for 302 or 351 ?Or are they one in the same ?
Will be using a/c from 65 coupe, no power brakes or steering, so what pulley setup is going to work
T-5 for fox body
Will be carb.
Thanks guys
