There is a sealant tape made specifically for petroleum products. It's yellow and I find it at the big box stores. I use that and haven't a leak in 11,000 miles.
Ray
Ray
https://www.amazon.com/Harvey-017065.../dp/B000FKBXCE
Yep, same ones.
Ray
Like all thread tape, it's very dependent on proper application. Wrap direction, tension etc.
Ray
