Results 1 to 12 of 12
Thread: Road Race floats for a Quick Fuel Carb?
    Member JRD56's Avatar
    Oct 2014
    Olathe, KS
    I'm just finishing up my build and I'm planning to do an autocross event with the local club. I'm running a stock Quick Fuel carb (SS-650 AN) on 5.0. I understand some of the cars running a carburetor may have an issue with fuel starvation on hard corners. I'm wondering if I need to put "road race" floats in the carburetor to help prevent this. And if I do, does it impact the normal driving on the streets. I know, I should have gone with fuel injection........
    Purchased and un-assembled Mk3 in 2016. 5.0, Aluminum heads, Performer RPM Air gap, Quick Fuel 650 carb, BBK headers T5, 3.55 rear solid axle, Koni Shocks, PS with Hydra-boost. Also own two restored vintage Mustangs, two Model A fords, 1941 Chevy truck and several other hot rods.
    I put them in mine w/ exactly the same carb and it runs great AX and street.
    Yes - road race floats.
    Jet extensions also help.
    I consider the Holley Avenger vent tube a necessity too - mostly keeps it from flooding on hard braking.
    Jax Beach, FL
    I have a Q series, which has the jet extenders. I think it has road race floats, but not positive. Never had a starvation issue.
    I haven't seen that vent extender, interesting. I did get a small header fire once in the shutdown area.
    At about 1:55 here:
    https://www.youtube.com/watch?v=eyVQxBr1KFA&t=112s
    Is that what it is for?
    Northern VA
    Hmm if I’m going to be doing track days and autox, are these items a must?
    Mark Dougherty's Avatar
    Hershey PA
    not a must
    BUT
    they sure do help.
    Without the above mentioned parts the carb will fload over, and want to stall under high G loads.
    The traveling Builder
    717-773-5624
    Northern VA
    Thanks for the info
    At about 1:55 here:
    That's it exactly.
    Also (probably) the black smoke at 3:15.
    Also, if you're working on it probably ought to make sure you've got vent baffles / whistles installed:
    Oct 2014
    Olathe, KS
    Thanks everyone for the reply's. I've got a set of roadrace floats on the way. I would think the floats would need to be notched for jet extensions, so I'll need to research that some.
    The vent tube mods make sense too, so I'm wondering if the tube shown above will fit on a Quick Fuel. Since Holley (actually High Performance Industries) now owns Quick Fuel I'll give them a call to discuss.
    My first Autocross event is in May so I've got some to time to work this all out.
    Jim
    Unconventional Builder Joee's Avatar
    Hatboro PA
    Quote Originally Posted by Mark Dougherty View Post
    not a must
    BUT
    they sure do help.
    I have not really had any problems and only noticed slight hesitation on big sweepers at Pocono AutoX.
    According to their site my SS 650 has •Race-ready with notched secondary floats and jet extensions
    So are my current QF floats and vent tubes ok or should I look into "race" floats and that Holley Avenger tube listed above ?
    Roadster Mk3 5294, 302 Comp XE276HR cam, AFR 185 heads, 650 Quick fuel carb, Air Gap intake, T-5 3.55 gear Levy Upper & Lower Front and Rear control arms Purch Jan 2008 Tagged Mar 2012 Best ET 12.14 @113** SOLD 4/8/18 **
    YouTube Videos: Current performance - https://www.youtube.com/channel/UC7c...86xO3U4l4RtVMQ Older build - http://www.youtube.com/user/joeembery#p/u My Pics:
    http://s207.photobucket.com/user/Joe...?sort=6&page=1
    Hershey PA
    Joe
    if you are happy then I am happy.
    if it aint broke ..........you know the rest
    717-773-5624
    Hatboro PA
    Thanks Mark
