WTB - Lots of parts for the GTM
Hello,
Hope someone is selling these: (brand new only) - or could you point me to the reputable online vendors where I can get this?
Thanks!
Exhaust piping system - engine to be used is a Dart 427 Twin Turbo LS7, 1250 - 1500 HP. Wegner Automotive will build it.
LH/RH E-brake backing plates (includes brake shoes and cylinders)
E-brake cables -
E-brake cable connection bracket (connects front cable to both rear cables)
LH/RH Exterior door handles with gaskets
Hood release handle and 2 attached cables
Wiper motor with rotating assembly and 3 mounting screws
LH/RH Seat belts w/upper bolt plastic covers
Seat belt receptacles
Steering column (w/stalks, 2 piece cover, steering wheel nut M14 x 1.5mm)(non-telescoping best)
