0
0
MK4 Donor pedal box question.
I am going to build my first base kit MK4. I am using a 1992 Mustang donor. I ordered the spacer from Replicaparts and frame mod from Whitby's. I plan on using the Mustang power brake booster. Do I need to shorten the brake pedal and do all the other mods to the pedal box as listed in the FFR manual?
Thanks for any advice from those who already done this. TW
Not a waxer
Pedal does not get shortened when using a booster.
With power brakes there is nothing to do. Bolt it in and go.
Thanks guys. That is what I was thinking but I feel better hearing from the pros.
- You may not post replies
- You may not edit your posts
Forum Rules
