Thread: primer& driving
    May 2016
    North of sacramento Ca.
    primer& driving
    Want to drive car and work on body this year. Is it OK to drive with primer and working on places.
    Senior Member TDSapp's Avatar
    Frisco, TX
    That is what I was planning on doing.... It's such a cool car even without paint no one would hold it against you.
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
    Oct 2014
    Vermilion, OH
    I put 2,900 miles on mine from the end of August to the first of December. It was amazing how many people told me to leave it that way and not paint it.
    CVOBill
    My understanding is the more you can keep the fiberglass and primer out in the sun where it expands and contracts, the better it will be when you start the final prep. I drove mine 2 years but it sat for nearly 6 years before I actually started working on it.
    Quote Originally Posted by 1932 View Post
    hell yes. I plan on the same - 1-2 years of driving and lots of tweaking and improving before final finish.
    Same here. I even like the look and plan to run it that way for a long time.
    Primer is permeable meaning that oils, etc. from the road can penetrate and get under it potentially leading to problems when you go to paint later. If you're going to do this use an epoxy sealer which is impermeable.
    May 2016
    Thanks Jeff
    Senior Member q4stix's Avatar
    Seattle, WA
    Can you clarify a bit? Is that an epoxy sealer in place of the primer or to go over it? Does the same apply to body fillers like bondo/rage, etc too?
    Gen 3 Type 65 Coupe builder
