Results 1 to 13 of 13
Thread: Supercharged 3.0T mated to 01E FWD
    Mar 2018
    Looking into an option for the 818. Does anyone know if the Audi 01E 6 speed FWD transmission from the Euro diesel would mate to the 3.0T from the 2010+ cars. CEL are of no concern, but the factory ECU would need to run the engine without inputs from the wheels/transmission. Other solution, mate the 3.0T to the wrx trans via adapter and only use front output shafts...(not preferred)
    http://advancedautomotion.com/shop/p...products_id=29
    Engine would be 2010+ S4 3.0t with OB4 Transmission - other option is to lock the rear output but I don't know if the trans would support 350-400hp that way.
    I am trying to figure out if the engine trans combo will work. The engine will fit, but I need to figure out if the transmission will fit and axles align within tolerance.
    Sum it up ---
    Audi 3.0T Engine
    Tranmission - Audi FWD 01E, Audi AWD OB4, Subaru with adapter
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    I've thought about using a 4.2 Audi V8 in the 818 as it's the shortest front to rear V8 out there making 400 HP. Have not look into the 3.0...
    Quote Originally Posted by TJRNT View Post
    Exactly what I needed to do for my build. You can stretch the axle tolerance quite much but it always feels weird and gives you less play when you want to play with suspension, so the closer to normal tolerance the better. But you have a margin.
    As for mating the trans to engine, try these guys, they know a lot about mating anything to anything.
    https://www.kennedyeng.com/
    Mar 2018
    Thanks for the heads up, I emailed them. I also contacted advancedautomotion and they stated it will mate. Would like a second confirmation of this though.
    Senior Member Blwalker105's Avatar
    The ob4 is the longest of the ob’s. How about the ob1 or ob3 fwd transmissions?
    They are all rated for up to 350 nm.
    Sgt.Gator's Avatar
    Bend, Oregon
    What the heck, go all out with a Hartley Maxi V8!
    H1 MAXI V8 SPECIFICATIONS:
    LAYOUT- 90 degree V8, flat plane crankshaft
    STANDARD DISPLACEMENT- 3.1 liters (turbo), 3.3 liters (NA)
    OPTIONAL DISPLACEMENTS- 2.5, 2.8, 3.0 and 3.5 liters (NA)
    WEIGHT- 96 kg
    BORE AND STROKE (STD)- 81 or 84 bore x 74 stroke
    COMPRESSION RATION- 13:1
    POWER- 420 TO 520 hp at 10,000 rpm (NA)
    TORQUE- 240 to 280 ftlbs
    VALVING- 4 cam, 4 valves/cylinder
    CLUTCH- 115mm or 140mm twin disc.
    SPECIAL FEATURES:
    Unique opposite offset cylinders reduces length of engine.
    Low profile sump with 100mm below crank centerline.
    Crankcase is machined from billet, 6061-T6 aluminum. Optional 7075-T6 alloy.
    6 stage oil pump including air/oil separator and water pump.
    Separate cylinders allow flexibility in displacement changes and servicing.
    http://www.h1v8.com/maxi-v8---specs.html
    Owner: Colonel Red Racing
    818R ICSCC SPM
    San Diego Ca 92106
    Yikes! $45k, slightly out of my price range.
    Sgt.Gator's Avatar
    Bend, Oregon
    I've spent $45K (total) on several Subaru engines that have turned into black holes of aluminum balls and shards between my 3 Subaru powered race cars. Not to mention all the races I've missed. For the same money I could have had a flat plane V8 singing the song of 11,000 rpm. There's a Palatov D1 that comes to ORP with a Hartley V8. The sound is friggin incedible.
    This is the original Hartley V8 in the D1. Hartley sold the production license to a manufacturer of prototype race cars, so that's why they had to come up with the new Maxi V8.
    Sorry for he threadjack, I just love looking at these engines!
    818R ICSCC SPM
    Mar 2018
    Kennedy Engineering has not attempted the mating of the Audi 3.0t to a 01E transmission.
    The OB4 was for simplicity coming from a wrecked S4. If I was going to install a new transmission I would prefer the durable and proven 01E transmission. Looking to do stage 2 and ultracharger, may put out more thank 350nm.
    These are literally one of my favorite engines! I would love to install one into a vehicle, but I would choose a different chassis, like a dedicated race car. I have seen the Palatov D1 and their other cars. Love the AWD setup they have in the one!
    Back in 98 (20 years ago) I had Kennedy make a custom adaptor for me. It was for my first EV, (Chrysler minivan).
    Adaptor was for an AC motor with a NEMA 210 C face to a dodge/crysler 5 speed trans axle. I think it was just under $200.
    I supplied them with a drawing with all the dimensions.
    http://www.evalbum.com/377
    Mar 2018
    Thanks for the info, I may end up going this route if necessary
    Mar 2017
    Looking into an option for the 818. Does anyone know if the Audi 01E 6 speed FWD transmission from the Euro diesel would mate to the 3.0T from the 2010+ cars.....The engine will fit, but I need to figure out if the transmission will fit and axles align within tolerance.
    I've updated my thread about all of this. Hopefully there is something helpful there.
    https://thefactoryfiveforum.com/show...p-transmission
