Has anyone successfully installed cruise control on a Coyote build? I have a gen2 crate motor and ecm. I have done some research but have not found anything that stands out. I am looking for a stand alone system that will work with the DBW throttle.
Very interested in this as well. (Not as far along, haven’t ordered the coyote yet, but soon.)
Have done a little research on Summit’s (etc) to see what’s available. Tried forum searches but found nothing of any substance.
Hoping to do some touring and traveling with the Cobra and thinking the cruise control would be helpful for fatigue and speed management.
I've seen this one mentioned by several builders. Interfaces to the Coyote DBW setup. Still requires magnets to be installed on the driveshaft with a pickup though. http://www.thecruisecontrolstore.com...-classic-cars/.
I installed one and it works very well with the magnets on the drive shaft. I tried to use the transmission out put to control the cruise functions but the operation was some what erratic. I didn't use the pulse divider on the transmission output so that may have been the problem. I wanted to make sure it worked OK with the drive shaft magnets and never went back to try it with the pulse divided in the transmission circuit.
King
Here is the DBW version of the system that I purchased. I too have the one with magnets on the driveshaft. But haven't been able to test yet to give an opinion. Just wanted to give you some info for you to research.
Cruise Control for Electronic Speedometers
Videos are at: YouTube Videos
I have the 250-1882 with dash pad, but have not drove car yet. The people at (the cruse control store)were very helpful.
Thank you all for the responses and input. I will look at these.
X2!
Many thanks all.
nice! adding this to research!
surprised you zip-tie magnets to the driveshaft works... is there no more permanent method?
Funny you should ask, I just installed one on my Mk4 with Gen2 Coyote and I love it. I finished it yesterday and drove 45 min on I70 to the autocross track this morning and back. It works beautifully! Like Paul said, the 250-1882 is what you need as it is for hotrod builds. There is a drop down menu that asks if you want the pedal interface harness for the coyote drive by wire. It is part number 250-2761 and it saves you a bunch of cut and solder work. Then there is another drop down menu for the controller. I chose the dash pad because I wanted it mounted out of sight under the dash. Part number: 250-3593 Universal Cruise Control Switch Dash Mount Without Engage light.
The magnets get epoxied to the drive shaft and a zip tie just holds them in place until it dries. I mounted the magnet coil sensor to my drive shaft safety loop. It takes a while to install the whole thing and is a little confusing at first, but if you call with questions they are very helpful and knowledgeable at the Cruise Control Store.
If you have a manual gearbox, why not just use a signal from engine ignition (rpm)?
My ‘87 4Runner has a crude cruise control unit that was installed somewhere between boat and dealer lot and that’s how it works — little vampire coil on #4 plug wire for speed sensor function.
The big “gotcha” is you need a disengage switch in the clutch arm as well as the brake arm, which you should have anyway.
