Results 1 to 13 of 13
Thread: Oil Pressure Sending Unit Issues-Speedhut
    Member bcsellie's Avatar
    Apr 2015
    I have the Speedhut Vintage Gauge set that was ordered with my kit. It says to use the oil pressure sender that came with the gauges, so I did so. I hooked up the signal and ground wires and it reads about 20PSI when the key is turned. When I start the car it remains about 20PSI higher than it should be....(and no Teflon tape was used). Thoughts?
    Blaine
    Blaine in Seattle
    Factory Five MK IV #8613 428CJ, IRS, Pin Drive,Tremec TKO 600, Trigo, Avon's,...(Viking Blue/Wimbledon White Stripes/Arctic White Meatballs)
    2011 Porsche Panamera Twin Turbo (Metallic Mahogany)
    1988 Porsche 930 Factory Slantnose Cabriolet (Guards Red)
    1974 Porsche 914 2.0 (Orange)
    Richard Oben's Avatar
    Kansas City MO
    Ground on the back of the gauge?
    Apr 2015
    Quote Originally Posted by Richard Oben View Post
    Just checked....looks solid.
    Blaine in Seattle
    bobl's Avatar
    Spicewood, Texas
    I had one that never read correctly and totally failed after about 1000 miles. Speedhut sent me a new one and it reads correctly now. So, I'd say there is a good chance your sender is bad.
    Grand Rapids, MI
    Ditto. I got a sender where the ground terminal was broke and the gauge didn’t read correctly because of it. They told me that they got a questionable batch of them. Call and they will send a replacement free of charge.
    X3 on the faulty sending unit. Speedhut are a good company. They sent me a new unit fast when mine failed on 1st start.
    Huntsville, Al
    x4.. same here
    I've had 2 or 3 Speedhut oil pressure senders fail on multiple builds. They have excellent customer service but unfortunately I can't say the same for their quality control.
    Apr 2015
    I'll contact Speedhut today...thanks guys!
    Blaine in Seattle
    I had two that were bad. Scary! Contacted them and third one working fine. Great customer service.
    I’ve had issues with my fuel pressure sending unit/gauge and called today and Speedhut immediately shipped me a replacement sending unit. They said it’s common and they were awesome about replacing.
    Apr 2015
    Quote Originally Posted by Eespensen View Post
    Don't the Speedhut fuel gauges work with standard ford fuel tank sending units? Simply calibrate them from the gauge with the included wire interface?
    Blaine in Seattle
    Apr 2015
    Quote Originally Posted by bcsellie View Post
    Disregard...I see "fuel pressure" now
    Blaine in Seattle
