Replacing bolt(s) on door.
Hello,
I have a bit of an issue with my driver side door in my roadster.
It has been sagging and not closing or opening very easy last summer, so I decided to adjust it.
The previous owner/builder cross threaded two out of the four acorn nuts on the door. Two loosened up and two did not.
I was able to use WD-40 and PB Blast and get one of the nuts off, but it took most of the threads off when it came off.
The last bolt came unattached from inside the door when was trying to loosen and tighten to free up. I ended up using an air grinder to remove the nut.
Pictures included to show this mess.
My question, has anyone replaced one of these bolts? If so, I’d like to inquire what you used, I’m thinking of using a marine-tex epoxy.
I figure to fill the hole with the epoxy and then coat the head of the bolt and insert, and then place the door in the hinge to insure properly alignment and let cure for a day or two.
Any better suggestions sure be appreciated. I want to inquire with those with more experience in this sort of fix then myself, before I attempt this repair.
Thank you.
