Hi Everyone,
I'm a newbee to the FFR roadster scene.
I've been waffleing about weather or not to get the FFR SS pipes or the mild steel.
I have a few questions:
1) How is the quality of the FFR pipes regarding the welds?
2) Are the SS pipes more dangerous than the mild steel as far as the potential to cause leg burns?
3) Will ceramic coating the mild steel pipes reduce the severity and possibility of leg burns?
Is ceramic coating the pipes worth the expense?
4) I've read, in this thread about using VHT high temp spray paint on the mild steel pipes, I never thought of that.
I didn't think the paint would hold up very well. How well does it hold up on the headers and 'J' pipes where the heat is
most intense?
Thanks in advance for your help with these questions.
Tom
