With some good help, I have the gauges and attachments wired up. I need to hang the dash to fit and wire the Russ T steering column.
I have no problem with having exposed screw heads showing on the front of the dash, but need help in positioning the dash and advise on any other issues involved with this.
I think I can cut the dash for the steering column and have a diagram for the wiring.
I have the plastic, pre covered dash that comes with the anniv kit.
Body is not on the frame, so I need the up and down position and are spacers needed behind the dash?
If you have link to your work, that might help, please include with any suggestions.
