Results 1 to 13 of 13
Thread: Whitby Power Brake Frame Mod
    Senior Member Norm B's Avatar
    I am converting to power brakes and ordered the frame mod from Whitby a month ago and haven't got the part yet. Anyone have the directions where to cut the frame to instal the frame mod. I am almost to the point of fitting up the booster but need to cut the frame and only want to do that once.
    Norm
    Norton, MA USA earth
    You could just skip the Whitby piece and do what I do.
    Cut the frame at 1 inch from the foot box and at 6 inches. Then buy another piece of tube that is 8 inches long and bolt it to the outside of the section you just cut out. Works perfect.
    mike
    I do the same as Mike. Don't forget to space the booster 3/8" forward of the front wall of the footbox.
    St. Louis, MO
    I looked at mine, but there is no way to get a good pic, or measurement of the cut closest to the foot box on my finished car. It might be best to give Jeff a call at Whitby.
    This is what the frame mod looked like on the Mk3 I had a few years ago. Pretty easy to see where it's cut.
    To Mike and Jeff's point, it does clear the booster by a lot.
    Thanks for the replies. I'll do as Mike and Jeff suggested.
    Jeff, I made a spacer out of 1/2 inch aluminum plate. That is what my measurements said I needed with my combination of a 95 pedal box and an 87 booster.
    For anyone contemplating power brakes, do it before the body is on! After is about as much fun as a root canal without anesthetic.
    Norm
    Tybee Island, GA
    Perhaps I can help. These are posts while I was trying to blog the build.
    Measuring
    http://buildacobra.blogspot.com/2015...rived.html?m=1
    Day 1 of install
    http://buildacobra.blogspot.com/2015...e-mod.html?m=1
    Day 2 of install
    http://buildacobra.blogspot.com/2015...-cont.html?m=1
    Videos are at: YouTube Videos
    Ohio
    I would recommend waiting for the mod till you have the part so you can get an exact cut. Also Replica Parts has a spacer that helps to seal the rubber on the back of the booster instead of just making a spacer. The booster directions call for 3/8” but the spacer they sold me was 1/2”. Called them and they said it was fine but after trying it out the pedal was too close to the footbox wall and needed to be moved toward the driver. I milled the spacer down to 5/16” and that gave the pedal a nice resting position more inline with the clutch pedal and still not making contact with the 3/4” tube welded in by FFR to keep the pedal from moving forward. Good luck.
    JRL16
    Member Kpt112's Avatar
    Bucks County PA
    Does anyone know what master cylinder and brake booster Whitby's is selling? I mean what car is it actually from? Just curious.
    Gorham, ME
    Instead of cutting the bar out, you can actually just cut a section out of the bar. Invert it and weld it back in. That way you don't have that odd looking jog in the bar.
    Worked on my Coupe.
    Gorham, ME
    I called Jeff at Whitby and they had not processed the order yet so I canceled it. I went with the mod suggested by Mike. Everything fits nicely. With todays weather I am thinking I should be building some sort of a snow machine.
    Power brake mod completed. Took the car for a drive and the brakes are great. It can be done with the body on but, changing the pedal is a challenge!
    Norm
