Thread: Unisteer Green wire fuse size
    Senior Member TomH33's Avatar
    Nov 2016
    Parker,CO
    Hi
    Any one know how much the green wire draws on a Unisteer setup. I have my owned keyed fuse panel and need to know what amp fuse to use.
    Thanks for your help
    RR20AC's Avatar
    Puyallup/WA
    I don’t have a green wire fuse but on the main red wire power side I have a 30amp slow blow fuse
    Placitas, NM
    I was testing out my Unisteer on the bench last night.
    More info than you probably want.....
    If the green wire isn't connected and the red and black are connected to constant power the Unisteer doesn't draw any current.
    When the green wire is connected to +12 you can here a relay inside the box energize, this relay then provides power from the constant +12 volt source.
    The green wire only draws 1ma (0.001 amps) of current.
    Nov 2016
    Parker,CO
    Thanks!
    I had a hunch that there was a relay involved. I'll just use a 5 amp 12V fuse and let the relay do the work.
