Thread: Aluminum floor not fitting it?? 33 Hotrod
    Placitas, NM
    I've been following the manual except for right now while I'm working on the wiring.
    I wanted to see how much room I'd have with the tranny tunnel and the floors sitting in place to hide some of the excessively long wires.
    I can't get the L & R floor pieces in.
    I can see that without the firewall installed the front vertical edges would fit thru the frame opening allowing the back of the floor to drop in place.
    I guess I could just lop off the vertical pieces and then use some angle aluminum to re-attach it.
    Did any of you have this problem?
    Senior Member stack's Avatar
    Macedon, NY
    they need to be bent to get them in. some of us cut that wing off and mount it to the outside of the frame for more foot room
    stack
    FFR MKI Roadster FFR2202K Built in 2000 sold
    FFR Hot Rod #39 under construction
    Placitas, NM
    Thanks, I cut the wings off both sides, much easier installation.
    No room under the tranny tunnel cover to hide all the wires.
    Quote Originally Posted by stack View Post
    stack
    Exactly.. not sure if it'll help much there (given I have clutch) but seemed silly not to mount to outside
