Results 1 to 12 of 12
Thread: LS3 Fuel Pump Circuit
    Village Mills, Texas
    I'm about knee deep in wiring and need some advice on the fuel pump. I have a LS3 376/480 and Boyd's tank with the Stealth 340 fuel pump. I have decided to let the ECM control the fuel pump since the FFR wiring is too small for the pump requirements. My questions are, is there a problem with grounding the pump to the chassis back by the tank and how to incorporate the inertia switch into the circuit. On the FFR harness, if I'm reading it correctly, the inertia switch brakes the ground to the fuel pump relay control circuit, but only uses 14 ga. wire.
    Placitas, NM
    You can ground the pump to the chassis if you want.
    I'm also knee deep in wiring and trying to figure out where to put everything.
    I'm using the ECM to control the fuel pump and the cooling fan.
    The inertia switch controls the inertia relay on the FFR fuse box. It should be breaking power to the relay coil, not power directly to the fuel pump. I'll look into this more tomorrow.
    I'm going to wire the inertia switch into the LS3 ECM fuel pump relay.
    Placitas, NM
    Looking at the supplied FFR wiring the inertia switch does provide a ground for the FFR fuel pump relay.
    The relay contacts send 12 volts on the tan wire that is in the rear harness connector to power the fuel pump.
    We need to use the ECM fuel pump relay and move the inertia switch in series with the ECM fuel pump relay.
    Both the FFR and ECM have a fan control, which I said I was going to only use the ECM fan relay.
    After thinking about this, they both use different sensors for controlling the fan.
    The FFR circuit uses the thermo switch on the side of the radiator to control the fan.
    The ECM uses the water temp sensor in the head above the #1 spark plug.
    I'm thinking about using both of them to control the fan, the wiring is already there, good back up just in case one circuit fails.
    Jim,
    My thoughts were to let the ECM and a/c control the cooling fan. The ECM measures engine temperature (the one I car about) not radiator temperature and the a/c will energize the fan any time it is on. The inertia switch needs to break the ground to the fuel pump relay coil. I haven't been able to find a wiring diagram for the LS3 fuse/relay box to identify where to access this ground. Does this make sense.
    This afternoon I pulled the engine fuse box back out, located the ground wire for the fuel pump relay coil, and spliced in the inertia switch. I also stripped the 14 ga. fuel pump power wire from the rear harness and replaced it with a 10 ga. from the engine harness. Two problems solved 9,999 to go. lol
    Placitas, NM
    Andy,
    This should help you. Oops, didn't see your above post. Maybe someone else can use it.
    Andy,
    Thanks Jim. Excellent illustration. I'm sure it will help someone in the future. That's what this forum is for. I hadn't wanted to remove the fuse box again but bit the bullet yesterday. I should have done it earlier.
    Placitas, NM
    Andy where did you mount the GM fuse box? I'm mulling it over right now.
    Last night I pulled out the inertia switch, it's wiring, and relay from the Ron Frances harness.
    I've got the switch connected to the GM fuel relay.
    It's almost impossible to mount the RF fuse box, the GM fuse box, the LS3 computer, the tranny computer, and the 15' of excess cable under the dash with the Vintage AC/heat box taking up most of the space.
    Need to figure out what plan B will be.
    I mounted the RF fuse box to the left of the pedal box. IMG_1132.JPG The ECM and GM fuse box are mounted to the right on a fabricated hinged mount. IMG_1133.JPGIMG_1134.JPGIMG_1137.JPG
    Placitas, NM
    Thanks for the pics Andy, looks good.
    Think I'm going to shorten some of the cables too.
    Still waiting for my aluminum to arrive so I can mount the Unisteer.
    Thanks Jim. I am looking forward to your PS install. I am going to have to do something with mine also. How do you plan to shorten the harnesses?
    Placitas, NM
    I'll start by taking the wires out of the corrugated tubing, pulling out what's not required, then get the correct length to where the wires need to be routed, get the cutters, strippers, and soldering iron out and start making them shorter.
    I'll take some pics.
