Thread: Headlighs & Turn Signals
    Senior Member jwebb's Avatar
    Longmeadow, MA
    Another off the wall question, I can attach the turn signal ground wire to the headlight ground wire correct?
    MK4 #9121 - Complete kit - Stroked 351, T5x, 3.55 Rear End, 3-Link - Pickup 6/17/17, 1st start 12/2/17, Go-Kart 12/9/17
    Yes I believe you can and that’s how I did it.
    Not a waxer
    Jeff Kleiner's Avatar
    Yes, ground is ground is ground is ground is ground is ground is ground is ground is ground...
    Longmeadow, MA
    Thanks, just double checking!!
    Woodstock ,Illinois
    Ground is ground?
    Quote Originally Posted by steno View Post
    Ground is ground?
    Yes, but sometimes ground is earth.
    There are 10 types of people in this world;
    those who understand binary and those who don't.
    Last time I fell off a ladder, ground hurt.
    I added a frame grounding point to each of the lighting plugs you can never have to many frame grounds
    Rick
    Been a long day. That made me laugh!
    Mark
    Mk1, Frame #1929 stock 1990 EFI 302, T5, 8.8 axle 3:55, PS, Heidts, heat, fresh air vents, Russ Thompson Turn Signal mod, windshield wings FFR front lower control arms.
Levy Racing
