how old is your kit? I know F5 made changes to the mounting bracket and supplied me with different bolts. send that pic to Tony
stack
FFR MKI Roadster FFR2202K Built in 2000 sold
FFR Hot Rod #39 under construction
I substituted a high strength button head Allen screw and was able to tighten it to the required torque (w/loctite) and it DOES clear the cable ferrule. I’m using the same IRS and brake calipers that you are. The bolts came from McMasterCarr.
Mine was similar although on a solid axle. I ground a flat along one side of the brass piece so it would slip over the head of the bolt.
Hi ! Was there any a solution to this post ? I am having exactly the same issue now. Especially the routing of the ebrake line is problematic. Thanks !
Did you find a good solution ?
I just finished this a month ago. I have a 2010 MK4 with old IRS. You will need to replace that hex bolt with a pan head (rounded) allen. It just gives enough room. I recall taking one of the caliper bolts out to rotate caliper up then install. When you press back down it's tight but fits. The cable runs to the side of the axle and lower control arm. I held in place with some zip ties. I will try and take some pics today and post. The IRS took some time as I installed a pulley system with Lokar setup as many others have reccomended.
Bryan
MKIV #7275 Acquired June 2019 (2010 partial build), Gen 2 Coyote by Forte w/TK600- PRO 5.0 - McLeod RST twin Clutch-QT Bell, old style IRS, 8.8 3.55 Rear, Gas'n Headers/Pipes, Power Steering, Hydroboost by Forte, Breeze Roll Bar, Heated Seats, 17" halibrand w/ Nitto G2, Maradyne Fan Controller, Paul Proe Vent Kit, Russ Thompson Signal w/ FTP- Received June 2019/First Start April 2020/Go Cart May 2020/Legal September 2020/PAINT BY SPOTLIGHT CUSTOMS JAN 2021
