Results 1 to 12 of 12
Thread: Tire selection
    Tire selection
    Looking for some advise on tire selection on Gen 3. What tire would you recommend? 325 or 335?
    Edmonton Alberta
    What wheels do you have or plan to get? I have 315/30/18 & 265/35/18 michelins on FFR wheels. The tires fit the wheels well width wise and they are plenty wide. There are not that many tires available in our sizes, it seems most newer cars are now going 20 inch + in the larger sizes and the tire selection reflects this.
    If you have 17's many are going with Nitto's.
    Also do a search, lots of prior discussions
    David W
    Mkll 4874 built in 2004
    David is exactly right. 315's are as wide as you can go with the available Factory Five 11-inch wheels. You might be able to get something wider in there with different wheels. But pay close attention to offsets. The inside tire sides are pretty close to the suspension already. The outside has a little more wiggle room. Many of us are using wheel spacers too, which factors in.
    Senior Member Duke's Avatar
    Taxachusetts
    NT01's or R888R's are solid options in 17's. Rival S's are also very well respected, but sometimes limited in sizes.
    I Have 18x9/11" 5 LUG HALIBRAND REPLICA WHEELS.
    Senior Member turbonut48's Avatar
    Milwaukee, Wi.
    I ve heard the NITTO 555G2 is a good choice. 200 treadwear rating. I have 555R right now. But when mine start wearing out, its the G2 s.
    I also heard theyre compatible with 555R on the rear.
    The Nut
    Mar 2013
    Fort Collins, Colorado
    Quote Originally Posted by turbonut48 View Post
    The Nut
    Nitto 555G2 is a 320 TW rating, not a 200.
    Huntsville, Al
    I am running 335 18's on the stock wheels from FFR... RIVAL TW200 they are very sticky
    Thank you everyone for the input.
    Senior Member stack's Avatar
    Macedon, NY
    Quote Originally Posted by Erik W. Treves View Post
    Front and rear?
    stack
    FFR MKI Roadster FFR2202K Built in 2000 sold
    FFR Hot Rod #39 under construction
    Huntsville, Al
    no... rears are 335...275's up front
    Milwaukee, Wi.
    I stand corrected. Tire wear rating is 320.
    The Nut
