Thread: Back Up Light Wiring
    Nov 2016
    Petaluma, CA
    As far as I can tell there is no power wire for a backup light in the rear harness. Where is the best place to pick up power? I'm assuming it is just a loop that puts the backup light switch that is in the TKO in series with the circuit?
    Correct. No wires for backup lights in the Ron Francis harness. Also correct, the switch in the transmission just completes the circuit when shifted into reverse gear. If the current draw of your intended fixture is low (e.g. LED) it could be piggybacked onto another circuit. Or onto an unused circuit, if you have one. Just make sure it's a ignition key switched circuit. Not an always on battery circuit. You don't want leaving it in reverse with the ignition off to drain the battery.
    Elk Grove, NorCal
    Joel
    Is your backup light permanent? Where did you mount it and what light are you using? If i need it for registration i might make it permanent or replace it with a permanent third brake light... or just remove it altogether. I do like the idea of a third brake light. On youtube videos from CSX’s in europe, ive seen light fixtures under the body or attatched to the bumper
    build thread: http://thefactoryfiveforum.com/showt...-USRRC-vspeeds
    Build School: July 14-16, 2017
    Kit purchased: July 25, 2017
    Kit delivered: September 13, 2017
    First Start: December 22, 2018
    Body painted and kit completed and drivable: July 2019 (but still not done)
    CA SB100 Registration: January 2020
    Mk4 - 289 USRRC Roadster kit, Roush 427SR with Schneider Racing custom camshaft, Fitech EFI, TKO600 (.64-5th gear), 15" wheels, stock brake calipers, under car exhaust with Spintech 7000 muffler, no roll bar, Russ Thompson turn signal, removable steering wheel, and many other small upgrades and modifications
    Nov 2016
    Petaluma, CA
    Hi, Sorry that I missed this post and question initially. I have the wiring in place for the back up light which I think we will need to go through the registration process in California. As yet, I have not chosen the light or made the decision whether or not it will be permanent. If I found the right light fixture that fit the car I might make it permanent. My car has gone to paint and so I won't see it for a bit. Maybe in the meantime I will start looking around for a light. If you find something you like, let me know. Joel
    Quote Originally Posted by japollon View Post
    My plan was to find something that complied and then remove after inspection. I bought a Grote #60721 Micro Nova DOT LED light. Grote is a good brand that we use on our commercial vehicles. The Micro Nova is 1" diameter. I had it zip tied to my bumper but my brake and light inspector wouldn't let that fly. Said it had to be permanently mounted. I made a small L bracket, cut the 1" hole and riveted to the bottom rear trunk aluminum. Now I plan to just leave it in place since you can't see it unless it is on. When it is on, it is very bright.
    I found a couple of bee hive lights, that felt matched the style of the existing lights. Lower wattage bulbs didn't require a relay, as the witch is heavy enough. Couple of Z shaped brackets mounted to the lower trunk frame, holds them in place.
    I look at the safety aspect of having them. It's a small car, and when backing out of a parking spot, I want it to be as obvious as possible.
    Nov 2016
    Petaluma, CA
    Thanks you guys for the back up light fixture input. Both of these are great solutions! Joel
