I hope the two pictures I just tried to attach come through.
Having difficulty installing the power steering rack to the front spindles. As you can see from the first pic, that's as far down the spindle will slide down the ball joint shaft. Once i put the spindle on the ball joint, there is only about a quarter inch of threaded shaft to screw on the lock nut.
Lastly, when I do get the whole thing together and start turning the wrench, the ball joint shaft start turning with the nut, so I can torque until Christmas but the nut won't progress.
FYI in the pics I removed the rubber cover so you can see the shaft better.
