Careful to the left of the steering wheel. That's where I put mine, but after the body was put on, there is some interference with the driver's side door when it's closed and the headlight switch is pulled all the way out. I had to angle the switch down by bending the dashboard slightly. It's still pretty close to the door!
Boy, that is something to consider. I would not have picked up on that with the body off. I guess it is back to the center area.
Thanks big time for the information.
