Results 1 to 2 of 2
Thread: Axle Adapter Bracket Bolts
    Mississauga, Ontario
    Hi,
    I am struggling with the bolts for the Axle Adapter Brackets. I'm using coil-overs, and the bolt to attached the lower coil-over assembly, the bracket and the shims is a 4" Larson Tuff Torq bolt, which is impossibly tight to push through the Axle Adapter Bracket. I can probably hammer it through, but it seems wrong to do so, and I am reluctant to drill out the bolt holes. Am I doing something wrong?
    Jonathan
    [email protected]
    Mississauga, Ontario, Canada
    289 USRRC Build started January 2018
    Driven on track in FFR by Bob Bondurant himself in 2005, Phoeniz, AZ
    Build School May 2011 (Strongly recommended)
    Answering my own question....I took a leap of faith and drilled out the bolt holes on the adapter bracket. What seemed like a big job took less than 5 seconds, so now I'm re-assembling my axle after worrying about nothing all week.
    Cheers!
    Jonathan
    [email protected]
