Thread: door sill in
    Gorham, ME
    door sill in
    I split the sill plate piece so I could fit the carpet underneath the edge for a more finished look.
    Today I installed the passenger side sill. Insulated the exhaust cavity, then installed the inside panel. Insulated the inside panel, then carpeted it.
    Finally topped it off with the sill plate. I had the painter finish the sill plate in red to complement the outside accent stripe.
    Edmonton Alberta
    any thought on protecting the paint from damage getting in and out of the car?
    David W
    Mkll 4874 built in 2004
    Gorham, ME
    David,
    I've been thinking about that too, and was wondering if the clear bra material would be a good option.
    Aug 2017
    Bedford VA
    clear bra material is a GREAT option.
    where did you get the sill?
    Did you make it?
    Gorham, ME
    Thanks for the feedback, yes I made it using the good old cardboard template technique!!
