Results 1 to 3 of 3
Thread: Solid Axle
    Solid Axle
    Just wondering before worrying - basically completed the suspension, steering and brakes. Installed Wilwood brakes (no emergency cables hooked up yet)) and brakes bled. Installed tires/rims and dropped the car to the floor. No driveshaft and rear is the FFR solid axle 8.8. When I go to push the car either forward or backward, I find it surprisingly very hard to push/move - it does, but doesn't roll easy - thought it would roll with ease. Fluid in the pumpkin. My Mk4 was way easier, but I did install an independent rear in that car. So my question/concern: is this normal? I don't see/think anything wrong -while I did successfully bled the brakes, can the rears have an airlock? basically locking them up (engaging)a little. MC linkage/adjustment seems OK. Again, I don't want to panic if it's normal and I should wait for the engine and let the car run/test to loosen up the rear?
    Any ideas - Thanks!
    Walter
    It should roll easily; at least mine does with a 2002 junkyard 8.8. I have no fluid in brakes yet, but connected the e-brake to stop it rolling around.. and air in brake lines would have the opposite effect - i.e. no brakes. Air is very compressible
    Seasoned Citizen NAZ's Avatar
    Brake(s) dragging. Put the car on jack stands and check each individually to find the culprit(s) and go from there with your troubleshooting.
