I'm just finishing up my Mk3 build. I'm finding the front tires are hitting the F-Panels. I running SN95 spindles from a 94/95 mustang. I used these spindles to minimize bump steer. Here is what I have. FF lower control arms mounted in the inner holes. If I mounted them in the outer holes the upper control arms are too short. I do have the nylon stops on the rack, I actually have two on each side. Wheels are FF 17 X 9 Halibrand replicas with 245-45-17 Nito tires. The tires do sit in some, so there is room to move them out. I'm looking options/opinions on a solution. Options I can think of:
1. Wheel Spacers. Not my favorite option.
2. Move lower LCA's to out holes. This would require longer UCA's but I'm not sure if anyone makes these?
3. Modified F Panels. I saw a mention of this on thread but can't find it now.
4. Live with it.
Also, anyone know how to search for multiple words. When I search for "F Panel", I get results for "Panel".
The car is a painted and I'm in final assembly. Should be on the road in a week or so but I'd like to fix this tire rub issue.
Thanks in advance for any help.
Jim
