FFR 65 Coupe-R kit selections below
60459 powder coat
60360 gauges
15440 coyote engine/trans mounts
60375 driveshaft - will need modified
60330 traced only cut outs
14262 std seat - will replace
16138 PS kit - but not needed
12066 std front control arms
60738 2015 IRS kit
15946 AODe adapter to IRS
60627 spoiler
60621 nose ducts
60622 rear ducts
15830 wipers
16563 battery cut off - weatherproof
16116 front sway bar
15998 IRS rear sway bar
60372 aero vents
15432 coyote accelerator kit
16237 IRS rear brake kit
IRS Center, spindles and hubs 3.27 ratio from LR
Optional parts from FFR
60472 - type 65 front aero bumper
80844 - 818 front canards
80718 - 818 carbon fiber front splitter
Ford coyote crate 9.5 to 1 CR part # M-6007-A50SCA
twin turbos 62mm - with custom exhaust
AEM Infinity series 7 ECM
100+ lb/hr injectors
Lentech 6R80 1200 HP build
Quick 6 Pro controller
cooler fitting adapter kit
SPI spec flex plate
Lokar ESS6R80HB 4” floor shifter -
Twist machines shrifter - steering wheel mount D9 paddles black polished with 6 bolt adapter
Circle D specialities - 258mm Pro billet 1C converter with 3 disk lock up, 3000-3200 stall
Wheels 18x9(?) front and 18x11(?)rear
Volk racing lightweight
Tires Toyo Proxes R888 295/30 R18 front and 335/30 R18 rear
Billet front control arms from LR
EPAS Electric power steering variable assist from JEGS #563-1012
Wilwood brakes from LR
Shocks from LR
Dry sump oil system from LR
Hayden trans cooler from LR - bypass model 11x11
Sparco Ergo seat X2 - from LR
Sparco R 353 steering wheel
Fuel cell with EFI pickup and fuel deliver system (pump, regular, filter) from LR
Paint and misc. from LR
Motor will be set up like this one 3 maps to flip flop out - gas, E85, race fuel - nice an easy 800-900 HP on gas or E-85, 1200+ on race fuel (hopefully)
http://www.mustangandfords.com/proje...coyote-part-2/
Levy Racing (LR) doing build - about to give him green light to go - comments?
