Results 1 to 5 of 5
Thread: About to remove body, cockpit brace question
    Senior Member shark92651's Avatar
    Feb 2018
    Frisco, TX
    I going to remove the body this evening and put it on the body buck. When making a brace for the cockpit opening, how much "give" does it need to easily remove the body without allowing it to overflex? The opening is about 35". Should I cut a notch that allows for 2" of flex or what is your experience?
    wallace18's Avatar
    Trenton, Florida
    The body hs a lot of flex to it. No need to do anything just watch the FFR video on you tube if you are hesitant. I have done it many times even after paint without any brace at all.
    Feb 2018
    Frisco, TX
    Yeah, I'm probably overthinking it as usual.
    Kirkland, WA
    The body brace was more for earlier versions. The Mk4 added sections that roll under the side of the chassis down the side which significantly stiffened it up in the cockpit area. I took the body off with me at the front and one kid at each rear corner. The body is very durable.
    Mk4 #8861 Complete kit. Delivered: 27 Apr 2016, currently a roller.
    Gen-2 Coyote, clutch, TKO600, midshift, and solid axle from Forte. Many pieces from Breeze and Replicarparts.
    Senior Member Yama-Bro's Avatar
    Jul 2012
    Kearney Nebraska
    Quote Originally Posted by shark92651 View Post
    Don't worry, that's one of my specialties as well. I took my body off without a brace in the cockpit. It flexed quite a bit. I did put a brace in the cockpit for storage. I've checked the brace a few times and it doesn't have much tension on it. I also supported the bottom of the sides with a couple pieces of crumpled up packing paper. So that could be helping.
    Like Wallace said, if you are worried about the flex, watch the FFR body removal video.
    https://www.youtube.com/watch?v=QokuC-jzLK8
    Purchased Complete Kit 6/9/2017, Delivered 9/4/2017, Rolling Chassis 3/30/2018, Engine Dyno'ed 3/4/2022, Engine installed 8/27/2022
    Serial #9158
