Results 1 to 10 of 10
Thread: MK4 Build - Coilover Hat Snap Rings
    Senior Member lewma's Avatar
    Jan 2018
    San Marcos, CA
    Guys
    I just started assembling the shocks and realized than none of the coilover hats have snap rings installed. The manual states to remove the snap ring to assemble the shock then install the snap ring again. Strange that not one of the hats came with snap rings. Did something change recently ?
    thanks!
    mark
    Build 2: Gen3 Coupe Complete Kit #309 Ordered 1/25/21, Delivered 6/9/21 - BluePrint GM 427 LS T56, IRS, AC, Power Steering. Album Here
    Prairieville, LA
    My kit was also delivered without snap rings. I called FFR and they sent them to me.
    MK4 #9237 - complete kit, Coyote, TKO600, IRS - Delivered 12/11/17
    Jan 2018
    San Marcos, CA
    Thanks, I'll contact them.
    Senior Member mlewis's Avatar
    Mar 2017
    Groton, Massachusetts
    Same with me. Called FFR, they sent them ASAP
    Mk4 #9165, Base Kit with lots of options, Delivery on 08/17/2017, Coyote, TKO600, 2015 IRS, 18" Halibrands, 12.99" Wilwoods
    Senior Member Fixit's Avatar
    Aug 2017
    Minneapolis 'Burbs
    Are the spring "hats" an FFR or Koni part?
    John D. - Minneapolis 'Burbs
    Pretty sure they are a koni part. The snap rings are not absolutely needed as long as the car stays on the ground. They are good to have for jacking up the car and in case you would ever get a wheel airborne over a rise in the road.
    Jan 2018
    San Marcos, CA
    Quote Originally Posted by Fixit View Post
    Koni Part from what I can see
    Jan 2018
    San Marcos, CA
    That was going through my mind too and wondered if that was why they never included them with the kit.
    I think that was just an error. A friend building a MkIV has them and I helped install them kind of after the fact.
    I originally thought they were missing, but then found them in some obscure box. They were simply labeled as snap rings and no details.
