Results 1 to 11 of 11
Thread: Fuel Pick-up for In-tank Pump & EFI
    Senior Member mlewis's Avatar
    Mar 2017
    Groton, Massachusetts
    Hi,
    Working on my fuel system. Using an in-tank e-pump and associated pick-up. The manual only addresses the external pump pick-up.
    Planning to drill out inlet for the return line as suggested for this unit. The manual also suggested to remove/disregard the "rubber piece" (i.e. duck-billed valve) at the end of the return line.
    Is this the case for the return line for the in-tank/e-pump set-up ?
    Thanks in advance
    Mark
    Mar 2017
    this is the section of the manual I am referring to:
    fuel pick-up by Mark Lewis, on Flickr
    I left mine on the return line with my in-tank electric pump. I haven't had any issues with it on and I feel like that's the way it came, so why change it.
    Mar 2013
    Medway, MA
    I have always drilled out the tips of the EFI pump supply and return lines to minimize flow restrictions. Be sure to de-burr the ID and especially the OD after drilling and blow out any chips.
    "The I.E." SoCal
    We've started using the Mass Flo in-tank hangers on all our customer cars. A bit pricey but we don't have to worry about upgrading it later if our fuel demand changes later on.
    http://www.promracing.com/fuel-suppl...-mustangs.html
    __________________________
    The Pro-M is a quality piece, just be sure to mark pressure and return before installing... They are the same size and can easily get mixed up.
    Mar 2017
    Quote Originally Posted by Mark Reynolds View Post
    Thanks Mark.
    I did drill out the inlet tip. What's your take on the rubber valve at the outlet end; leave it on or off ??
    Thanks others for the recommendation on the Mass Flo pick-up. Looks like a nice unit. I'm think I will stay w/ what I got to try to save a couple of bucks (for something else ...)
    Senior Member Norm B's Avatar
    The rubber piece is a spray nozzle to spray return fuel on the pump. Its purpose is to provide pump cooling when fuel quantity is less than about 1/3 tank. I’d leave it on.
    Norm
    Mar 2017
    interesting...
    I thought it was a check valve of some sort. I'll ignore the manual and leave it on.
    Mark
    Richard Oben's Avatar
    Kansas City MO
    Or just buy a Mustang in tank complete assembly and bolt it in. As long as it has enough supply volume. JMHO, Richard.
    Mar 2017
    I thought I would use the in-tank/pick-up received from FFR.
    Was interested to know how it relates to the external pump/pick-up assembly that is (only) shown in the manual where the mod's to the pick-up are suggested (i.e. drill lout of the return line inlet and the removal of the "rubber piece" at the end of the return line)
