Thread: Driver side rear wheel rubbing on bracket
    NY
    Did the 5 lug swap and installed new PS Engineering wheels on the 3 link rear. Drivers side wheel is rubbing slightly on shock bracket. Wondering if just grinding the bracket would be ok ? Rear seems centered correctly as the driveshaft has no binding, thanks all
    Any room to adjust the track toward the other side? If not, some 1/4 inch spacers could solve the problem.
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    A pic would help us be sure but I am relatively confidant that grinding the corner of the bracket will be OK.
    Jax Beach, FL
    My wheel would hit the panhard bracket when doing autocross. I did some grinding and it is good now. It is surprising how much the wheels flex when you really pu some side load on them.
    I am not a fan of wheel spacers. I would rather get the grinder out.
    O'Fallon, MO
    Grind the bracket, its been done many times.
    NY
    Grinded bracket, all is good. Had to do both sides as passenger side wheel weight was hitting bracket
