Thanks Phil and Frank.
Frank, to clarify, you went with the 4-piston front and 4-piston rear Wilwoods right? You did NOT go with the 6 piston fronts right?
I used the stock WRX fronts cause they are a good size
for front use. Wilwood on fronts would be fine but I thought
the stock were ok. The rears caliper piston size is THE problem on the 818. Thus I just
purchased the Wilwood rear kit with a substituded
bigger rear caliper. Good luck.
