Results 1 to 5 of 5
Thread: Trunk Weather Stripping
    Tybee Island, GA
    Could someone provide me with a photo/dimensions of the trunk weather stripping that the trunk lid rests on when latched. I'll need to purchase some from McMaster.
    I'm assuming it looks something like this link: TOP ROW - SECOND FROM LEFT or FAR RIGHT https://www.mcmaster.com/#bulb-seals/=1cvr6mj
    Videos are at: YouTube Videos
    I think you have selected the correct type: Second from Left, top row. Here is what mine looks like: (sorry I don't have an uninstalled piece to show you)
    However, before you order some of this, I think you should have it in your kit. It came with mine. Check and see if you got it, and if you didn't, contact FFR. Hope that helps.
    The kit does come with bulb seal for the trunk. It's the smaller size with the bulb on the side vs. the top. But if you have to buy new, or choose to buy new, get 1120A411 from McMaster. It's exactly the same as the kit provided bulb seal except the edge thickness is for 1/4-inch vs. 1/8-inch. It fits over the fiberglass body edge much better.
    Mar 2013
    Medway, MA
    Tybee Island, GA
    Quote Originally Posted by Mark Reynolds View Post
    Thanks for the part number Paul and Mark
    10' length from McMaster-Carr P/N 1120A411
