Results 1 to 3 of 3
Thread: no startup
    Jan 2018
    no startup
    2017 rf harness,vintage guages, blue print 306 ford with sniper efi wont start. hand held monitor for efi is showing no rpm signal (wont sync with ecu). i connected grey wire from distributor to rf coil tach wire but no go. any suggestions?
    Did you connect +12V to the coil?
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    Jun 2015
    Fairfax Station VA
    Are you using the Sniper system to control timing? If so, have you set that parameter to "yes" during setup?
    That was the problem I ran into when I tried to first start my Terminator system...
    MK IV Roadster #8631
