0
0
Engine Compartment Ventilation
So I've had an idea after driving the GTM for several years now about how to better ventilate the engine compartment. Figured summer is coming up so I finally did it. Basically, I made two hatch supports that can pivot up from inside the engine compartment and support the hatch in an open position, so it is even with the rear wing. This should let significantly more heat out and create better airflow around the engine and exhaust. Soon as it stops raining here (7+ days) I'll test it out and report back.
-Michael
SOLD JUNE 2018 - GTM #327, LS3, G50/20, Kooks, AC, Ron's Tanks, Crash's 4-port HCV, Shane's Bolts & Plenum & etc., plus a lot of other stuff. Finished November 2013.
Not-up-to-date Build Site:
http://rumrunnergtm.weebly.com
