Thread: LUCAS switch retainer rings
    Mar 2014
    Louisville, KY
    So, I purchased Lucas swithes for my dash from Finish Line.
    Some came with hex nuts, Wiper switch came with ring collar.
    Since I'd like them to match and I dont much care for the hex nut look.
    Does anyone know of a reliable supplier for the Lucas style collars?
    Build 1: MkIV Roadster #8675. Deliv: 8/15/2015.
    FFR MkIV complete kit. / 5.0 Coyote Motor / T56 Magnum Trans / 2015 IRS / 18' Halibrand w/Michelin Pilot Sport PS2 Tires
    FFMetal: Firewall Forward, Trans Tunnel top, Battery Box, Fan Shroud
    Russ Thompson: Turn signal Assembly, Trunk Box Mod.
    Breeze: SS Roll Bars(2), Power Steering rack, and much more.
    Mike Forte: supplied 5.0 Coyote & T56 Magnum Trans
    Unfortunately, I don't know where to get just the front hardware. I do know some Lucas style switches sold by ********** are reproductions. I too have noted they don't always match and the quality isn't quite to Lucas standards. And that's not saying much.
    I've been buying mine from here: https://www.autoelectricsupplies.co.uk/product_list/255. Parts are marked with the Lucas brand name and logo and are in the Lucas green box.
    Santa Clarita, CA.
    Here are a couple links. Keep in mind that original Lucas are metric and some of the reproductions are not. The two are a bit different but should compliment one another if you have both types in your dash.
    I believe these are the correct Lucas slotted rings. Switches fitting 14.5mm holes. Currently out of stock but I purchased most of my switches from these guys and they should be able to help you. Send them an email. They are pretty good about getting back to you.
    http://www.autoelectricalspares.co.u...hes-2565-p.asp
    These should fit the Standard thread pitch toggles that fit the 1/2" hole
    https://www.tubesandmore.com/product...-switch-chrome
    Correction: These will not fit Original Toggle Switches but look correct.
    https://www.holden.co.uk/displayprod...?pCode=020.258
    I suppose you could also just buy a couple extra simple Lucas toggle switches. Would end up paying $12 per ring. Remember to reach out and verify metric or standard.
    https://www.ebay.com/itm/MG-Toggle-S...wAAOSwGotWlogE
    https://www.ebay.com/itm/lucas-SPB20...MAAOxy4fBTktuU
    Mar 2014
    Louisville, KY
    Thank you both for the info. I'll give those a try.
