JDAV had a really good write-up on this topic last year, but he's using an extra relay. Hopefully, I only need one. You decide. So here's the situation: I'm installing the RT turn signal as I write this. I'm a bit at a loss connecting the VW relay. Please check out the photos here, too. Based on JDAV's posting last year, I connected the Ron Francis Headlight dimmer switch wire to post 56. The RF brown high beam wires went to 56a; the RF red low beam wire went to 56b. That leaves post 30 and post s.
The premise is that I'm using the VW relay so I can dim the headlights with the stalk button. I don't care about flash to pass. So...
1. what goes on post 30? one of the leads from the stalk switch?
2. what goes on post S? the other lead? Or something else?
Here are my photos:
I look forward to your ideas here!
