I have decided to sell my Roadster. It has been very reliable and an absolute blast to drive.
My car was featured on the cover of the 2017 Factory 5 Roadster Owners and Builders Group Calendar and also was the October feature car. Car was Completed in October 2016.
As you will see by the list of "extras" the forum members did a good job of spending my money.
Engine & drive train:
*Ford Strokers Prepped Block
*ARP Fasteners Throughout
*Scat 3.400" Stroke Steel Crank
*4.030" Bore
*347 Cubic Inches displacement
*Kevco 8 Quart Trap-door Oil Pan
*AFR 185 Aluminum Heads with 2.02 and 1.60 Valves
*AFR Stud Girdle
*Comp Cams Ultra Gold 1.6 Roller Rocker Arms
*Comp Cams HR 274 XE Hydraulic Roller Cam
*Forged Steel Rods
*Forged Aluminum Pistons
*10.8:1 Compression Ratio
*Weiand Stealth Coated Intake Manifold
*Holley 670 CFM Street Avenger Carb
*MSD "E" Curve Distributor with Steel Gear
*Mikes Replica Parts Alternator Bracket Kit
*100 Amp One Wire Polished Alternator
*Mini High Torque Gear Reduction Starter
*Gas-N Polished Stainless Steel Headers
*Gas-n Polished Stainless Steel Side Pipes
*Taylor 8mm Ignition Wires
*King Cobra Clutch
*Tremec T5Z 2.95:1 Low Gear 5-Speed Transmission
*3.55:1 Traction Lock Rear End
*Pro 5.0 Shifter
*North Racecar 5 Bolt Rear Axels
Engine Cooling:
*Aluminum Radiator
*Adjustable Thermostatic Cooling Fan Controller
*Polished Aluminum Speedway Motors Overflow Tank
*Thunderbird 2 Speed Radiator Fan with Shroud
Suspension and Brakes:
*3 Link Rear Suspension
*Tubular Upper and Lower A Arms
*North Racecar Rear Caliper Brackets
*North Racecar Parking Brake Lever Kit
*11.65" Rear Brake Discs
*SN95 Front Spindles
*Cobra Front Brakes with PBR Calipers
*Koni Coil-Over Shocks on All Four Corners
*Hydroboost Power Steering and Brakes
*3 Turn Power Steering Rack
*Roll Control/Line Lock
Wheels and Tires:
*Halibrand Replica 17x9 Front and 17x10.5 Rear 5 Bolt
*Nitto 555 245x45ZRx17 Front and 315x35ZRx17 Rear
Body & Exterior:
*Guardsman Blue with Wimbledon White Stripes Including under Hood and
Trunk. Base Coat/Clear Coat
*Full Set of Polished Stainless Steel Bumpers and Over-riders.
*Polished Stainless Steel Side Louvers
*FFR Sun Visors (not shown in pictures)
*FFR Wind Wings
*Windshield Mounted Center Rear View Mirror
*Windshield Post Mounted Side Rear View Mirrors
*Chrome Roll Bar with Tangent Hidden Connector for Down Tube
*Tangent Driving Light Grill Kit
*3M Clear Spats (Not in Pictures)
Interior:
*Competition Style Dash with Classic Instruments with 5" Tachometer and 180MPH Reverse Rotation Speedometer
*Breeze Adjustable Seat Installation Kit
*Cobra Heat Seat Heaters
*FFR Heater
*Mikes Replica Parts Under Dash Filler Panel, Shifter and E Brake Trim Rings
*Herbs Door Panels
*Russ Thompson Gas Pedal and Aluminum Covers for Brake and Clutch pedals to match.
*Leather Steering Wheel (Wood Rimmed Wheel A;so Included)
Trunk:
*Mikes Replica Parts Gas Strut Trunk Support Kit
*Carpeted Trunk Interior
Electrical:
*American Autowrire Harness
*Ear Cannon Horn (LOUD)
*AGM Battery Mounted In Engine Compartment
Priced at $37,900
DSC00171 by Chuck Sloggett, on Flickr
DSC00140 by Chuck Sloggett, on Flickr
DSC00143 by Chuck Sloggett, on Flickr
DSC00085 by Chuck Sloggett, on Flickr
DSC00166 by Chuck Sloggett, on Flickr
DSC00326 by Chuck Sloggett, on Flickr
r
