Thread: Two different floats
    Senior Member TDSapp's Avatar
    Frisco, TX
    So I started converting and rebuilding my carburetor yesterday. It is a Holley 4160 which I am converting to a 4150 by adding a second metering block and jets. I started pulling it apart yesterday and found that apparently someone has been into it already. It has two different floats in it. I know that you can buy either one as a replacement but was wondering if the two different materials would cause any problems.
    What do y'all think?
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
    No problem using different floats.
    Mark Dougherty's Avatar
    Hershey PA
    all the new quick fuel carbs I have installed come the same way.
    The traveling Builder
    717-773-5624
    Frisco, TX
    Quote Originally Posted by Mark Dougherty View Post
    So I guess in this case all of the primaries are metal and the secondary is plastic. I figured that the PO of the carb had gotten into it.
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
