Am swapping SpeedHut classic gauges to replace the base FFR set. Can I tap into the harness at the dash or do I need to run the SpeedHut gauge wire from the tank?
Kevin
MKIV #8234
No reason to run new wires if the existing ones are OK. The resistance range is in the sending unit itself. The sending units included in the kits typically calibrate to the Speedhut 16-158 ohms range.
Thank You
Kevin
MKIV #8234
