Results 1 to 6 of 6
Thread: 2 post lift - still need frame dolly?
    Apr 2018
    Colgate, WI
    I have a 2 post lift for the build. Any reason to also build a frame dolly if I don't need to free up the lift until build is done? Thanks.
    Mark Dougherty's Avatar
    Hershey PA
    nope
    The traveling Builder
    717-773-5624
    Senior Member Fixit's Avatar
    Aug 2017
    Minneapolis 'Burbs
    Not unless the daily driver breaks... or the lift breaks... I'd build a rudimentary/simple dolly just in case you need to move the Roadster chassis.
    John D. - Minneapolis 'Burbs
    Mark Eaton's Avatar
    Medford, Oregon
    Feb 2017
    Birmingham, AL
    I use my 2 post lift and 4 cheap movers dollies under the tires or with some blocks under the frame to move it around when the lift is simply in the way (which is a lot of the time)
    Apr 2018
    Colgate, WI
    Thanks for the comments. Will go with the wheel dollies and use a couple 4x4 cross members if I need to move the frame before wheels on.
