I have a 2 post lift for the build. Any reason to also build a frame dolly if I don't need to free up the lift until build is done? Thanks.
nope
The traveling Builder
717-773-5624
Not unless the daily driver breaks... or the lift breaks... I'd build a rudimentary/simple dolly just in case you need to move the Roadster chassis.
John D. - Minneapolis 'Burbs
These are pretty handy though
https://www.harborfreight.com/1000-l...-pc-61283.html
I use my 2 post lift and 4 cheap movers dollies under the tires or with some blocks under the frame to move it around when the lift is simply in the way (which is a lot of the time)
Thanks for the comments. Will go with the wheel dollies and use a couple 4x4 cross members if I need to move the frame before wheels on.
