Thread: ID these modules
    South Jordan, Utah
    ID these modules
    What are these modules? One attaches to the bottom of the steering column and has a frequency. 2007 WRX
    Leesburg, VA
    (1) keyless entry module - controls door locks, I deleted this one (2) not sure, alarm? immobilizer?, (3) integrated unit module - controls interior lighting, I deleted this one too.
    Aug 2017
    Unhappy
    The second one is the immobilizer.
    The only thing the integrated unit module does is interior lighting? So we don't need it, or any of its wiring?
    Asking for a friend . . . (who may or may not have damaged it)
    Leesburg, VA
    Quote Originally Posted by Ipassgas View Post
    Correct, you do not need the integrated unit module. If you have a wrx cluster, you'll need to run a power wire from somewhere (fused headlight power?) because it provides power for cluster illumination. Unless you have an sti cluster, which is illuminated by default.
    AZPete's Avatar
    Roy, I see these guys have ID'd your modules, but have you seen this thread? It ID's all the terminals, modules and other mysteries and was a life saver when I dieted my wiring:
    (thanks again, Mechie3!)
    https://thefactoryfiveforum.com/show...h-Auto-AC-HVAC
    818S/C : Chassis #25 with 06 WRX 2.5 turbo, ABS, cruise, PS, A/C, Apple CarPlay, rear camera, power windows & locks, leather & other complexities.
    Jul 2017
    The Villages Fl.
    Another good way to ID parts is to just google the numbers on the item.
Flat Irons Tuning
