Is it a bad idea to go cart witout using tbe supplied exhaust hanger? The reason I ask is I would imagine that placement would change once you get the body fitted correctly?
Thanks Craig
Thanks Craig
MK4 #9028 - Coyote - TKO600
Delivery: 1/30/17 First Start: 7/23/17 Legal: 10/5/17 Graduated: 10/15/18
Build thread: http://thefactoryfiveforum.com/showt...8-Build-Thread
I drove mine for 4 years and 3500 miles over some pretty rough roads with no issues. Because of the height of my pipes I couldn't use the FFR supplied hangers and ended up making my own and installing them as a winter project this year. A few go cart miles should be fine.
I used some metal strap to make hangers from the door hinges to the pipes. I don't want to put the real hangers on until the car is basically finished.
Delivered: 6/17/2017
First Start: 12/30/2017
Completed: 12/7/2019
Legal: 1/30/2020
Did you just rap them around the muffler onto the hinges or use the muffler mounted hole?
Legal: 1/30/2020
many guys dont use the han
gers at all ...ever. If you are running headers I doubt you will have any problem
I always advise to use the hangers on completed cars but you'll be fine to make a couple runs around the block as a go-cart (I don't get the whole 10-20-50 miles as a go-cart thing but that's just me ). Absolutely wait until the body is in it's final position before installing the hangers permanently; the rocker panels have to move in &/or out for panel fitting which often means making adjustments or adding shims to get the pipes parallel to the body.
I agree with Jeff. You will be fine for a couple of go kart runs.
I recommend them. However, I have broken a header twice, once with and once without hangers. Some guys have run for years without them and no issues.
Just hook a bungie strap on the door hinge and the other end in the pipe.
I run with no hangers so far. 1400 miles.
I think my headers from 2005 were made by another supplier but, 41000 miles w/o hangers and all is well.
