Today's topic is Coyote cooling. It even sounds good, doesn't it?
I've asked a couple of you off-line for input, and now I'm asking for opinions on placement. I'm checking the placement of my radiator expansion tank, both vertically and horizontally, side-to-side. Wareaglescott cautioned me on allowing room for the hood hinge; Edwardb commented on vertical placement. Please take a look at these photos:
First,
Here, we can see that the top of the reservoir is pretty much level with the forward frame rail. That should be sufficient to clear the hood, yes??? It also shows, from a distance, so to speak, the side-to-side position relative to the hood hinge. Good?
Next,
a closeup of the tank and the hood hinge. Please keep in mind that I moved the hinge as far "out" as possible. What do you think? Enough clearance?
Finally,
An overhead view of the gap between the air intake elbow and the tank. Enough space, or do I need to move something?
I look forward to your input. Once I get everything in the correct spot, I can finish fabricating my mounting brackets. Thanks, guys!
