All
What is everyone using to fasten down the fuel tank access panels in the roadster trunk aluminum ? Don't really want to rivet those down and wondered if there was a good fastener to use so I can remove those panels if needed ?
thanks!
mark
All
thanks!
mark
Build 2: Gen3 Coupe Complete Kit #309 Ordered 1/25/21, Delivered 6/9/21 - BluePrint GM 427 LS T56, IRS, AC, Power Steering. Album Here
A lot of guys install rivet nuts, myself included, to secure the access panels.
I've gone overboard and used the #10X24 with a 1/8" button allen head screw for my dash, transmission tunnel top, stereo and all access panels.
https://www.rivetsonline.com/aluminu...m-rivet-nuts#1
You can see some of my stupidity (aka: WORK) around 1:47 - 2:10 in the attached video:
https://youtu.be/IGYtX-3p7xk
I used rivnuts
Rivet nuts here as well. No need to use anything larger than 6-32. One thing to note is that the fuel pump side is too small if you go with an in tank fuel pump.
F5R #7841: Anniversary Edition MK4, Ford Racing 427, Edelbrock EFI, Gas-N Pipes, Stainless Headers, TKO600, 3.31 Moser 3-Link, 17" Halibrands
I screwed mine down with the rivnuts as well. However, I don't think it matters whether they are screwed down or riveted. Rivets are easily drilled out if it becomes necessary to remove them. I've had to access my tank twice and both times I had to drop the tank for the needed repairs. The access panels didn't help.
King
I used the same 10-32 rivnuts I used all over the car for hard-or-impossible-to-access-the-back-side places. I also made a larger access panel over the fuel pump so when the time came, its much easier to swing the wrenches, cap lines and wiggle the pump assembly out.
MK IV Roadster #8631
Thanks everyone
As an alternative, dome head self tapping SS screws. The holes are already drilled in the access panels.
Rivnuts also, I did make my fuel pump access panel bigger than what FF had. The larger opening will come in handy when I change fuel pumps in the future to accommodate EFI requirements.
Doug
FFR 7995
347 SBF Prestige Mototsports, Moser 8.8 (3.31) 3 Link, TKO 600, Nitto 555s, 17" Halibrands, PS, AC, Heat, Color Redfire Pearl, with Wimbledon White Stripes
If you need to make larger access panels, just go to your local ACE Hardware, Lowes or Home Depot and pick up an aluminum door kick plate.
You can even pick a different color if you want to "Bling Things Up" a bit.
