Ford Sterling Companion flange for IRS?
On the 'other' forum, a guy posted that you can change the companion flange on the 2015 IRS differential, using a Ford Sterling flange that adapts directly from the 31 spline to a 1350 joint. Says it is the flange from a F250/350 SuperDuty with a 10.25/10.5 Sterling Ford axle.
Has anyone else investigated this?
Paul
