Hey guys. I've probably read more about this than I need to, but lots of conflicting info out there. I'm planning on running 3/8" fuel line, which will consist of -6AN stainless flex line from my tank to a steel or Nicopp hardline underneath the car, then another stainless flex line to the carb. Question is flares or compression fittings? I don't have a flaring tool and seems that the fittings would be much easier. Summit has some AN to tube adaptor fittings (SUM-2200077B).
As a side note, I looked at the nylon flex lines as well. Would be great to run just one line front to back, but have noted that some are smelling fuel and can be compared to a soaker hose?
Thought I'd bring this back up and get some current opinions. Thanks.
