Results 1 to 3 of 3
Thread: Heater hose clearance
    Village Mills, Texas
    Does anyone have an idea on the minimum distance between a heater hose with a Summit heat sleeve and the header. Right now it is about 2 inches between the two. I am not running a hood or side panels, so that should help some.
    wallace18's Avatar
    Trenton, Florida
    You should be OK. Here is a pic of the LS 33 I recently built. No problems with it after 3K miles in FL heat.
  3. Thanks HVACMAN thanked for this post
    Placitas, NM
    Wallace, thanks for that pic, I was going to post a question about how much space there was past the frame for those heater and AC hoses.
